Linux Mint 18.1 - pomalý start [vyřešeno reinstalací] Vyřešeno
Picc4so
#1 Příspěvek od Picc4so »
Nazdar Linuxaci,
mam taky problem, ze mi strasne dlho startuje NB, mam Toshibu Portege Z30, I5, SSD disk a 12GB RAM a start trva neskutocne dlho, niekde na forach som nasiel prikaz ktory mi vypise co kolko pri starte trva ale neviem co dalej, zistil som toto:
30.009s systemd-rfkill.service
           520ms lvm2-monitor.service
           490ms apt-daily.service
           461ms plymouth-quit-wait.service
           460ms plymouth-quit.service
           402ms NetworkManager-wait-online.service
           373ms dev-sda2.device
           296ms upower.service
           223ms ModemManager.service
           209ms accounts-daemon.service
           171ms systemd-logind.service
           153ms NetworkManager.service
           148ms avahi-daemon.service
           144ms thermald.service
           123ms irqbalance.service
           121ms loadcpufreq.service
           102ms grub-common.service
            97ms ondemand.service
            94ms virtualbox-guest-utils.service
            92ms preload.service
            90ms speech-dispatcher.service
            85ms console-setup.service
            79ms cpufrequtils.service
            66ms virtualbox.service
            58ms networking.service
            58ms colord.service
            58ms systemd-udev-trigger.service
            57ms binfmt-support.service
            56ms pppd-dns.service
            55ms gpu-manager.service
            54ms systemd-fsck@dev-disk-by\x2duuid-D214\x2d4534.service
            51ms systemd-tmpfiles-setup.service
            48ms systemd-user-sessions.service
            47ms systemd-journald.service
            47ms rsyslog.service
            46ms udisks2.service
            46ms keyboard-setup.service
            45ms polkitd.service
            41ms alsa-restore.service
            36ms systemd-modules-load.service
            35ms lm-sensors.service
            29ms ntp.service
            28ms user@1000.service
            23ms openvpn.service
            19ms systemd-hostnamed.service
            19ms systemd-udevd.service
            17ms systemd-update-utmp.service
            16ms plymouth-start.service
            16ms hddtemp.service
            14ms dev-mqueue.mount
            14ms boot-efi.mount
            13ms sys-kernel-debug.mount
            13ms plymouth-read-write.service
            12ms console-kit-log-system-start.service
co s tym "30.009s systemd-rfkill.service" viem spravit ?
Dik Palo
Linux Mint 18.1 Serena 64-bit na Toshiba Portege Z30, Intel® Core™ i5-4200U CPU @ 1.60GHz × 4, 12GB RAM, 128GB SSD
Re: pomaly start
Mohol by si zadat v terminali prikaz:
sudo systemctl disable systemd-rfkill.service
Picc4so
Re: pomaly start
#3 Příspěvek od Picc4so »
prikaz som pouzil, uz tuto funkciu nespusta ale stale je start 1min. 35s. otrasne :-(
Picc4so
Re: pomaly start
#4 Příspěvek od Picc4so »
po zadani systemd-analyze critical-chain mi to vypisalo toto:
graphical.target @1min 30.978s
└─ntp.service @1min 37.870s +17ms
  └─network-online.target @1min 30.881s
    └─NetworkManager-wait-online.service @1min 30.479s +401ms
      └─NetworkManager.service @1min 30.284s +166ms
        └─dbus.service @1min 30.261s
          └─basic.target @1min 30.257s
            └─paths.target @1min 30.257s
              └─systemd-networkd-resolvconf-update.path @1min 30.257s
                └─sysinit.target @1min 30.245s
                  └─systemd-update-utmp.service @868ms +15ms
                    └─systemd-tmpfiles-setup.service @785ms +81ms
                      └─local-fs.target @779ms
                        └─run-user-1000-gvfs.mount @1min 35.877s
                          └─run-user-1000.mount @1min 35.263s
                            └─local-fs-pre.target @592ms
                              └─lvm2-monitor.service @186ms +405ms
                                └─lvm2-lvmetad.service @258ms
                                  └─lvm2-lvmetad.socket @183ms
                                    └─-.mount @153ms
                                      └─system.slice @155ms
                                        └─-.slice @153ms
a to som uz uplne v koncoch :-(
Re: pomaly start
#5 Příspěvek od menom »
A co je v tom vypise cervenym pismom ?
Na tvojom mieste by som kukol co pisal Kamowski a pohladal pre jednotlive polozky ci nemaju
nieco ako
ExecStart=/usr/bin/nm-online -s -q --timeout=30
a timeout znizit z 30 naprikad na 2 sekundy
--timeout=2
ODKAZ:
viewtopic.php?f=15&t=2744&p=18100&hilit ... yze#p18100
Potom to restartnut a ak to nepomohlo, tak skusit ten prvy prikaz s "mask"
Picc4so
Re: pomaly start
#6 Příspěvek od Picc4so »
no, skusal som skusal, az mi spadol system, a po preinstalovani celeho NB (ktore trvalo asi 40min) je start tak 3-5s.,
ale dik za ochotu pomoct ;-)
