glmark2 - nízké hodnoty
for redhawk75 Tak dalo to 69, 70 a naposledy 164
Re: glmark2 - nízké hodnoty
Tak teď 352:-) si to žije vlastním životem:-)
tak znova, po inštalácii glmark2 som mal glmark2 hodnoty okolo 320 po pridani repozitarov Oibaf a Padoka klesli hodnoty zo dna na den z 209 na 190. Je to možné?
Prikladám inxi -G a inxi -F
inxi -Gxxx
Graphics: Card: Intel Core Processor Integrated Graphics Controller
bus-ID: 00:02.0 chip-ID: 8086:0046
Resolution: 1600×900@60.00hz
GLX Renderer: Mesa DRI Intel Ironlake Mobile
GLX Version: 2.1 Mesa 17.3.0-devel – padoka PPA Direct Rendering: Yes
inxi -Fxxx
System: Host: edel-Latitude-E6510 Kernel: 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.4.6 (Gtk 3.18.9-1ubuntu3.3) dm: mdm
Distro: Linux Mint 18.2 Sonya
Machine: System: Dell (portable) product: Latitude E6510 v: 0001
Mobo: Dell model: 02K3Y4 v: A01 Bios: Dell v: A17 date: 05/12/2017
Chassis: type: 9
CPU: Dual core Intel Core i5 M 520 (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9575
clock speeds: min/max: 1199/2400 MHz 1: 1333 MHz 2: 1599 MHz
3: 1333 MHz 4: 1599 MHz
Audio: Card Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Sound: Advanced Linux Sound Architecture v: k4.8.0-53-generic
Network: Card-1: Intel 82577LM Gigabit Network Connection
driver: e1000e v: 3.2.6-k port: 7040
bus-ID: 00:19.0 chip-ID: 8086:10ea
IF: eno1 state: down mac: 00:26:b9:f5:87:4a
Card-2: Intel Centrino Advanced-N 6200
driver: iwlwifi bus-ID: 02:00.0 chip-ID: 8086:422c
IF: wlp2s0 state: up mac: 00:27:10:11:c7:80
Drives: HDD Total Size: 750.2GB (18.4% used)
ID-1: /dev/sda model: ST750LM022_HN size: 750.2GB serial: S2SUJ9GC911888
Partition: ID-1: / size: 46G used: 9.7G (23%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 634G used: 112G (19%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 8.44GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: System: supported: N/A
Unused Devices: none
Sensors: System Temperatures: cpu: 37.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 216 Uptime: 30 min Memory: 1394.2/7780.9MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481 running in gnome-terminal-) inxi: 2.2.35
inxi -Gxxx
inxi -Fxxx
Chassis: type: 9
hovori za vsetko.
Asi to nebude vhodne na kazdy HW to slovo develGLX Version: 2.1 Mesa 17.3.0-devel – padoka PPA Direct Rendering: Yes
hovori za vsetko.
Asi to bude rozbitý, ale nic si z toho nedělej ...
knobloch@knobloch-pc ~ $ inxi -G
Graphics: Card: Intel Device 1902
Resolution: 1920x1080@60.0hz
GLX Renderer: Mesa DRI Intel Skylake DT GT1 GLX Version: 3.0 Mesa 10.5.9
Tak na to můžu říct jenom " no je to dost"
Poslouchám nyní todle: https://www.youtube.com/watch?v=Yh_jfqXghDI
V hlavičce v terminálu mám jiné údaje než ty, proto ty diametrální rozdíly ...
knobloch@knobloch-pc ~ $ glmark2
glmark2 2012.08
OpenGL Information
GL_VENDOR: Intel Open Source Technology Center
GL_RENDERER: Mesa DRI Intel(R) Skylake DT GT1
GL_VERSION: 3.0 Mesa Re: glmark2 - nízké hodnoty
skrob@skrob-Vostro-3700 ~ $ glxinfo | grep "OpenGL version"
OpenGL version string: 2.1 Mesa 17.3.0-devel - padoka PPA
Cleaner není
Oibaf by měl být, zkusím znovu
Cleaner není
Nainstaloval jsem to znovu, restart a glmark2
