Sony Vaio VGN-TX3XP
pan_velkomozny
Sony Vaio VGN-TX3XP
#1 Příspěvek od pan_velkomozny »
Zdravim, dostal sa mi do ruk spominane Vaio a som sneho na prasky. Cokolvek za OS tam dam (XP,W7,W10,Mint,Lubuntu,...) tak to ide neskutocne zasekano. Nemate niekto nejaku radu? Ci len vyhodit do kontajneru? :D :D :D
Re: Sony Vaio VGN-TX3XP
Ked si vyskusal tolko OS a nejede to, moze to byt HW problem
Instalacky linuxu mavaju moznost spustit Memtest pre kontrolu RAM
A este skontrolovat harddisk na vadne sektory ....
pan_velkomozny
#3 Příspěvek od pan_velkomozny »
test som skusal ako prvy, vsetko v poriadku aj ram aj hdd, skusal som aj vymenit ramku ale neuspel som, nieje totiz kalsicka DDR2 ale nejaka upravena priamo pre sony... do hodky som pri stroji, hodim vypis co je to za zelezo
pan_velkomozny
#4 Příspěvek od pan_velkomozny »
System: Host: peter-VGN-TX3XP-B Kernel: 4.8.0-53-generic i686 (32 bit)
Desktop: MATE 1.18.0 Distro: Linux Mint 18.2 Sonya
Machine: System: Sony product: VGN-TX3XP_B v: J001VA0W
Mobo: Sony model: VAIO Bios: Phoenix v: R0021N3 date: 05/09/2006
CPU: Single core Intel U1400 (-UP-) cache: 2048 KB speed: 1200 MHz (max)
Graphics: Card: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics Controller
Resolution: 1366x768@60.23hz
GLX Renderer: Mesa DRI Intel 945GM x86/MMX/SSE2
GLX Version: 1.4 Mesa 12.0.6
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.8.0-53-generic
Network: Card-1: Intel PRO/Wireless 3945ABG [Golan] Network Connection
driver: iwl3945
IF: wlp2s0 state: up mac: 00:13:02:cd:56:34
Card-2: Intel PRO/100 VM Network Connection driver: e100
IF: enp6s8 state: down mac: 00:13:a9:3f:cf:64
Drives: HDD Total Size: 80.0GB (9.2% used)
ID-1: /dev/sda model: TOSHIBA_MK8007GA size: 80.0GB
Partition: ID-1: / size: 72G used: 5.5G (9%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 1.60GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 60.0C mobo: 59.9C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 151 Uptime: 29 min Memory: 498.5/1496.4MB
#5 Příspěvek od menom »
Na takyto stroj skusit LM 17.3 s Mate alebo Xfce
Alebo linux MX-16 v 32-bit verzii
Este mozno pohladat novsi BIOS a upgradnut ak existuje ...
pan_velkomozny
#6 Příspěvek od pan_velkomozny »
Ntb prepastovany, vycisteny, nainstalovany mint mate 17.3 a ide do celkom obstojne oproti doterajsim distram. Len teplota CPU a MB moc neklesla, cca o 3stupne. Vdaka za rady pani :)
