Po inštalácii LM nefunguje wifi a bluetooth
roman.kupec
#1 Příspěvek od roman.kupec »
Ahojte,
mam notebook Lenovo Thinkpad T 410. Po inštalácii Linux Mint 17.3 Rosa mi nefunguje wifi ani bluetooth.
Tu su nejake vypisy aj so zadanim prikazov z inej diskusie na ukazanie informacii o karte pre wifi:
inxi -F
System: Host: roman-ThinkPad-T410 Kernel: 3.13.0-24-generic i686 (32 bit)
Desktop: Cinnamon 2.8.8 Distro: Linux Mint 17.3 Rosa
Machine: System: LENOVO product: 2537V28 v: ThinkPad T410
Mobo: LENOVO model: 2537V28
Bios: LENOVO v: 6IET79WW (1.39 ) date: 07/15/2011
CPU: Dual core Intel Core i5 M 520 (-HT-MCP-) cache: 3072 KB
clock speeds: max: 2400 MHz 1: 1199 MHz 2: 1199 MHz 3: 1199 MHz
4: 1866 MHz
Graphics: Card: Intel Core Processor Integrated Graphics Controller
Display Server: X.Org 1.15.1 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1440x900@60.0hz
GLX Renderer: Mesa DRI Intel Ironlake Mobile x86/MMX/SSE2
GLX Version: 2.1 Mesa 10.1.0
Audio: Card Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k3.13.0-24-generic
Network: Card-1: Intel 82577LM Gigabit Network Connection driver: e1000e
IF: eth0 state: up speed: 100 Mbps duplex: full
mac: f0:de:f1:09:5f:be
Card-2: Intel Centrino Advanced-N 6200 driver: iwlwifi
IF: wlan0 state: down mac: 00:27:10:5b:a2:30
Drives: HDD Total Size: 167.9GB (9.0% used)
ID-1: /dev/sda model: ST9160412AS size: 160.0GB
ID-2: USB /dev/sdb model: DataTraveler_2.0 size: 7.9GB
Partition: ID-1: / size: 143G used: 7.1G (6%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 4.08GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 40.0C mobo: 0.0C
Fan Speeds (in rpm): cpu: 3600
Info: Processes: 159 Uptime: 1:15 Memory: 720.9/3831.1MB
dmesg | grep Wire -A12
[ 10.475964] Intel(R) Wireless WiFi driver for Linux, in-tree:
[ 10.475967] Copyright(c) 2003-2013 Intel Corporation
[ 10.476147] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 10.476286] iwlwifi 0000:03:00.0: irq 44 for MSI/MSI-X
[ 10.506759] thinkpad_acpi: ThinkPad ACPI Extras v0.25
[ 10.506763] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 10.506765] thinkpad_acpi: ThinkPad BIOS 6IET79WW (1.39 ), EC 6IHT41WW-1.16
[ 10.506767] thinkpad_acpi: Lenovo ThinkPad T410, model 2537V28
[ 10.511888] thinkpad_acpi: detected a 16-level brightness capable ThinkPad
[ 10.512038] thinkpad_acpi: radio switch found; radios are disabled
[ 10.512054] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[ 10.512056] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 10.514466] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is blocked
roman.kupec
Re: Po inštalácii LM nefunguje wifi a bluetooth
#2 Příspěvek od roman.kupec »
Stiahol som, ale instalacny prikaz neviem. Prosim napovedu pre laika. Neviem, ci je vsetko v ovladacom paneli, instalaciu som zvladol, ale inak tu o tom systeme viem velmi malo. Dakujem.
#3 Příspěvek od menom »
Mozno by si mohol dat vypis ci neni vypnuta wifi:
rfkill list all
A este:
dmesg | grep iwl -A12
roman.kupec
#4 Příspěvek od roman.kupec »
Pisu , ze je vypnuta, ale co dalej?
fkill list all
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: yes
1: tpacpi_wwan_sw: Wireless WAN
Soft blocked: no
Hard blocked: yes
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
roman@roman-ThinkPad-T410 ~ $ dmesg | grep iwl -A12
[ 10.514830] iwlwifi 0000:03:00.0: Direct firmware load failed with error -2
[ 10.514833] iwlwifi 0000:03:00.0: Falling back to user helper
[ 10.516983] thinkpad_acpi: rfkill switch tpacpi_wwan_sw: radio is blocked
[ 10.519116] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[ 10.524609] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 10.526154] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input8
[ 10.536915] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
[ 10.539190] device-mapper: multipath: version 1.6.0 loaded
[ 10.562090] hda_codec: CX20585: BIOS auto-probing.
[ 10.562535] autoconfig: line_outs=1 (0x1f/0x0/0x0/0x0/0x0) type:speaker
[ 10.562537] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.562539] hp_outs=2 (0x1c/0x19/0x0/0x0/0x0)
[ 10.562541] mono: mono_out=0x0
[ 10.562542] inputs:
[ 11.170113] iwlwifi 0000:03:00.0: Direct firmware load failed with error -2
[ 11.170116] iwlwifi 0000:03:00.0: Falling back to user helper
[ 11.249498] iwlwifi 0000:03:00.0: loaded firmware version 9.221.4.1 build 25532 op_mode iwldvm
[ 11.371994] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 11.371998] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 11.372000] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 11.372002] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Advanced-N 6200 AGN, REV=0x74
[ 11.372102] iwlwifi 0000:03:00.0: L1 Enabled; Disabling L0S
[ 11.379023] iwlwifi 0000:03:00.0: RF_KILL bit toggled to disable radio.
[ 11.449007] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 11.847320] Linux video capture interface: v2.00
[ 11.946597] usbcore: registered new interface driver usbserial
[ 11.946620] usbcore: registered new interface driver usbserial_generic
[ 11.946633] usbserial: USB Serial support registered for generic
[ 11.960098] uvcvideo: Found UVC 1.00 device Integrated Camera (17ef:480f)
[ 11.961388] input: Integrated Camera as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input16
[ 11.961565] usbcore: registered new interface driver uvcvideo
[ 11.961567] USB Video Class driver (1.1.1)
[ 11.983298] usbcore: registered new interface driver qcserial
[ 11.983318] usbserial: USB Serial support registered for Qualcomm USB modem
[ 11.983350] qcserial 2-1.4:1.1: Qualcomm USB modem converter detected
[ 11.983672] usb 2-1.4: Qualcomm USB modem converter now attached to ttyUSB0
vxmery
#5 Příspěvek od vxmery »
Toto si skúšal ?
Linux Mint 21.3 Cinnamon 64b
Livan
#6 Příspěvek od Livan »
Podľa výpisu to máš vypnuté hardvérovým vypínačom, Zapni to podľa postupu, ktorý ti dal vxmery.
roman.kupec
#7 Příspěvek od roman.kupec »
ĎAKUJEM. Nevšimol som si ten vypínač a nerozumel som, čo znamená hardvérom vypnuté (keďže som o vypínači nevedel), lebo aj v menu to bolo napísané.
Urobil som to podľa návodu v biose. Po zapnutí vypínača hneď svietili na monitore ikony wifi aj bluetooth. V biose však bolo aj tak všetko "enabled", tak neviem načo to bolo treba robiť v biose. V každom prípade to funguje, nemá to nič spoločné s inštaláciou. ĎAKUJEM VŠETKÝM ZA POMOC!
Livan
#8 Příspěvek od Livan »
To v tom BIOSE bolo iba pre prípad, že by to tam bolo vypnuté. V podstate iba kontrola, či je všetko v BIOSE povolené, čo povolené má byť.
roman.kupec
#9 Příspěvek od roman.kupec »
Aha, dakujem.
