Windows 7 a Linux Mint dualboot [vyřešeno]
Zdravim, momentalne mam na notebooku nainstalovany Windows 7 a chcel by som si vedla neho nainstalovat aj Linux Mint ako dual boot. Lenze stale ako spustim instalacne LiveCD a pokusim sa instalovat tak v tretom kroku instalacie mi namiesto dvoch moznosti (instalacia vedla win alebo na cely disk) zobrazi len moznost nainstalovat na prazdny disk a nad tym ne napisane ze na disku nieje ziadny iny operacny system. Prosim vas nevedeli by ste mi poradit ako by som to mohol vyriesit skusal som uz aj rozne rozdelenie lokalneho disku vo windowse na particie ale nepomohlo.
Re: windows7 a linux mint dualboot
Aby som ti neradil odveci potreboval by som odpovede Terminalu na 2 prikazy.
Mohol by si to instalacne dvd spustit ako LiveCD/DVD - vyskusat bez zmien v systeme.
Po nabehnuti na pracovnu plochu otvoris Terminal a napises alebo okopirujes postupne tieto prikazy (za prikazom Enter):
Potom to sem cele okopiruj.
sudo fdisk -lKód: Vybrat vše
sudo parted -l.
sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0xdaeafd5a
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 976771071 488282112 7 HPFS/NTFS/exFAT
[b]
mint@mint ~ $ sudo parted -l[/b]
Warning: /dev/sda contains GPT signatures, indicating that it has a GPT table.
However, it does not have a valid fake msdos partition table, as it should.
Perhaps it was corrupted -- possibly by a program that doesn't understand GPT
partition tables. Or perhaps you deleted the GPT table, and are now using an
msdos partition table. Is this a GPT partition table?
Yes/No?Re: windows7 a linux mint dualboot
Tak mas na disku tabulku s particiami GPT- WARNING: GPT (GUID Partition Table) detected on '/dev/sda'!
TY si musis teraz rozmysliet ci sa mienis zaoberat a skusat aj inymi Linux distribuciami ako Ubuntu.
Pretoze GPT byva od vyroby nainstalovane spolu s Windows alebo novsie Instalacky ti nedaju na vyber pri instalaci Win a rovno vyzaduju GPT.
Ubuntu a zopar distier podporuju Secure boot a preto vedia pracovat aj s GPT, vacsina Linuxov vsak nema tuto lahodku od M$.
Tu je tema kde sme riesili podobnu vec s Fedorou, ked este nevedela Secure boot:
A da sa to tak, ze zmenis Partition Table (tabulku partici ) na harddisku na msdos.
Ale tymto sa ZMAZE VSETKO Na disku a musis si nanovo dat Windows a potom Linux.
Podobne ako tu:
Samozrejme potrebujes k tomu dualbootu aj Instalacny disk pre Win7.
Rozmysli si ci ti staci dualboot s ubuntu - ten vie aj secure boot a nevadi mu GPT.
Ale do buducnosti ak budes chciet skusit Plny vykon aj ineho Linux systemu tak je lepsie si urobit Tabulku partici msdos.
Napriklad cez LiveCD a program GParted.
http://linuxos.sk/komentare/25886/Ale tymto sa ZMAZE VSETKO Na disku a musis si nanovo dat Windows a potom Linux.
Podobne ako tu:
http://linuxos.sk/komentare/25886/#link_207447Rozmysli si ci ti staci dualboot s ubuntu - ten vie aj secure boot a nevadi mu GPT.
Dakujem ti velmi pekne za tvoju pomoc
Zase som o nieco mudrejsi
rozhodol som sa nakoniec ze si urobim tu tabulku particii msdos a teraz vsetko fici jak ma aj ked to bolo trosku zdlhave ale stalo to za to. Este raz dik.
Správne rozhodnutie.
Keďže si to zvládol sám, vidím že si skúsený používateľ Linuxu.
Všetci sa neustále učíme nové veci a verím, že to má zmysel - skúšať nové a zdokonaliť to čo už poznáme.
