Esprimo Mobile U9200 a WiFi [vyřešeno]
MiroslavBodlák
#1 Příspěvek od MiroslavBodlák »
Zdravím a předem hlásím, že jsem nováček, i když staršího data. Mám na svém Esprimu nainstalovanou Mayu. Po bootu WiFi jede v pohodě, ale jakmile noťas usne tak po probuzení většinou WiFi není ani v ifconfigu.
Prosím o radu a předem dík, přikládám lspci.
mirek@ESPRIMO ~ $ lspci
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 03)
00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (secondary) (rev 03)
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
04:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8055 PCI-E Gigabit Ethernet Controller (rev 14)
06:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02)
mirek@ESPRIMO ~ $
Powerbook G4/1.67GHz, MorphOS 3.1 reg.
Amiga 1200, B1230/40->50, OS3.9
FS Esprimo Mobile U9200, Qiana (Xfce)
segfault
Re: Esprimo Mobile U9200 a wifi
#2 Příspěvek od segfault »
MiroslavBodlák
#3 Příspěvek od MiroslavBodlák »
Díky za link, vyzkouším a dám vědět jak to funguje. A začnu hned u první možnosti....
MiroslavBodlák
#4 Příspěvek od MiroslavBodlák »
Tak zdá se, že po jednom dni to funguje, ještě jednou dík.
Edit. 22:13
Tak asi teda ne..... Po vyvenčení psa se noťas probudil opět bez připojení :shock:, holt zkusíme druhou variantu.
MiroslavBodlák
#5 Příspěvek od MiroslavBodlák »
A jsem v koncích, jakožto neználek potřebuji poradit v té druhé verzi, cituji:
This second method will most likely work if the first one does not:
sudo touch /etc/pm/sleep.d/wakenet.sh
sudo chmod +x /etc/pm/sleep.d/wakenet.sh
sudo gedit /etc/pm/sleep.d/wakenet.sh
Až potud to jde, ale nevím co vše se má zapsat v následujícím:
Insert the following lines:
#!/bin/bash
case "$1" in
thaw|resume)
nmcli nm sleep false
esac
exit $?
Save
#6 Příspěvek od kamowski »
- týmto vytvoríš v adresári /etc/pm/sleep.d/ nový súbor: wakenet.sh
- týmto mu nastavíš príznak - spustiteľný
- týmto si ho otvoríš na editáciu v textovom editore "gedit"
ak taký nemáš, prepíš na pluma, leafpad, ... podľa toho, ktorý máš nainštalovaný
otvorí sa ti prázdny súbor, do ktorého Ctrl+C -> Ctrl+V:
#!/bin/bash
case "$1" in
 thaw|resume)
esac
exit $?
potom stlač Ctrl+S alebo klikni na "uložiť" a súbor zatvor
edit: nemá ten pes v obojku nejakú rušičku? :D :D :D
MiroslavBodlák
#7 Příspěvek od MiroslavBodlák »
Jasně, díky za návod a vysvětlení, hlavně mi nebylo jasné jestli se má zkopírovat vše, takže provedeno, a opět dám vědět jestli se podařilo. Jestli se můžu zeptat, co je to "esac"?
:lol: A ten obojek jsem prověřil, a kupodivu je bez rušičky :lol:
#8 Příspěvek od kamowski »
http://tutorialspoint.com/unix/case-esac-statement.htm
ak som to dobre pochopil, "case" je inteligentnejší spôsob zadávania viacerých "if"
a esac je ukončenie
case-esac (čítaj odzadu)
MiroslavBodlák
#9 Příspěvek od MiroslavBodlák »
Tak zatím to vypadá že by to mělo být v pořádku, jen jednou se noťas neprobudil, ale to bylo po instalaci, jinak je to zatím v pohodě, takže díky za rady.
Amigo64
#10 Příspěvek od Amigo64 »
Tak se opět po čase ozývám: Po instalaci posledního Mintu Xfce 17 je v tomhle směru vše OK. Možno uzavřít.
Asus Zenbook UX32VD, Xubuntu 18.04 LTS
Powerbook v5.8, G4/1,67GHz, MorphOS 3.14
Motorola G7+, Android 10.0
