Externa DVD mechanika
vlado.mt
#1 Příspěvek od vlado.mt »
Zdravim.
Nedari sa mi rozbehat externu dvd mechaniku kupil som externy box Qoltec USB3 Sata a do neho som vlozil mechaniku co som mal v notase .
po pripojeni do USB mi to len pipne no pravdepobne nerozpoznalo ze tam je dvd mechanika lebo nic nespustim ani nic nenacita,otvorit suflik a vlozit dvd tam ide aj sa tvari mechanika ze ho cita no z pc nejak viazne komunikacia asi.... hladal som aj cez google no zatial bez uspechu ...
prosim poradte co stym
vdaka
vlado.mt
Re: Externa DVD mechanika
#2 Příspěvek od vlado.mt »
Device= 1.04
[ 299.496214] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 299.496217] usb 3-4: Product: Ini-3910
[ 299.496219] usb 3-4: Manufacturer: Initio
[ 299.496221] usb 3-4: SerialNumber: 303030303030303030303030
[ 299.531731] usb-storage 3-4:1.0: USB Mass Storage device detected
[ 299.532055] scsi host6: usb-storage 3-4:1.0
[ 299.532200] usbcore: registered new interface driver usb-storage
[ 299.534048] usbcore: registered new interface driver uas
[ 299.578338] [UFW BLOCK] IN=wlp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:23dc:cfd7:090a:b900 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=794508 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 299.578355] [UFW BLOCK] IN=wlp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:23dc:cfd7:090a:b900 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=712045 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 299.588632] [UFW BLOCK] IN=wlp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:23dc:cfd7:090a:b900 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=794508 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 299.588656] [UFW BLOCK] IN=wlp3s0 OUT= MAC= SRC=fe80:0000:0000:0000:23dc:cfd7:090a:b900 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=712045 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 300.542540] scsi 6:0:0:0: Direct-Access Initio Ini-3910 0104 PQ: 0 ANSI: 6
[ 300.543220] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 300.544534] sd 6:0:0:0: [sdc] Attached SCSI removable disk
Bus 003 Device 002: ID 13fd:3910 Initio Corporation
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x13fd Initio Corporation
idProduct 0x3910
bcdDevice 1.04
iManufacturer 1
iProduct 2
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x8b EP 11 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0a EP 10 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
vlado.mt
#3 Příspěvek od vlado.mt »
Ako obvykle by mohol ukazat vypis z terminalu
lsusb
a
lsusb -t
co je to za mechanika ...
vlado.mt
#5 Příspěvek od vlado.mt »
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 4: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 6: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 6: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 2: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 3: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 4: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
vlado.mt
#6 Příspěvek od vlado.mt »
Bus 002 Device 003: ID 5986:0295 Acer, Inc
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 0cf3:3004 Atheros Communications, Inc. AR3012 Bluetooth 4.0
Bus 001 Device 003: ID 04d9:a01c Holtek Semiconductor, Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 13fd:3910 Initio Corporation
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
#7 Příspěvek od menom »
Podla tohto vidi system velkokapacitne ulozisko .
a
podla tohto treba hladat :
co dalej ...
vlado.mt
#8 Příspěvek od vlado.mt »
menom píše: 23 kvě 2020, 22:10 .
a
co dalej ...
A co stym dalej,neda sa to nejako prepnut cez terminal aby to bralo ako DVD mechaniku a nie ulozisko?
#9 Příspěvek od menom »
Ako prvu pomoc by si mohol spustit program Disky alebo Disks a tam kuknut ako sa to javi ...
#10 Příspěvek od menom »
Podla toho co hladam tak ti polozim otazku - myslis si ze ma ta dvd mechanika dostatocne napajanie cez ten
ramik, do ktoreho je vlozena ?
Co zatial vidim, tak mozno ma malo voltov, neni tam moznost pripojit externy zdroj ?
