- zkusil jsem knihovnu odstranit, coz ale nejde, jsou tam dulezite zavislosti (az po cely Cinnamon)
- zkusil jsem knihovnu preinstalovat nejnovejsi verzi, ale to mi taky nejde
- zkusil jsem znovu nainstalovat cely Cinnamon, to ale taky nejde, pry mam "broken dependencies"
kucerakm@PRAGWS142 ~/Downloads $ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following extra packages will be installed:
libjson0 libjson0-dev
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/113 kB of archives.
After this operation, 74,8 kB disk space will be freed.
Do you want to continue [Y/n]? y
dpkg: error processing libjson0 (--configure):
libjson0:amd64 0.9-1ubuntu1 cannot be configured because libjson0:i386 is in a different version (0.10-1.2yavdr3)
dpkg: dependency problems prevent configuration of libjson0-dev:
libjson0-dev depends on libjson0 (= 0.9-1ubuntu1); however:
Package libjson0 is not configured yet.
dpkg: error processing libjson0-dev (--configure):
dependency problems - leaving unconfigured
dpkg: error processing libjson0:i386 (--configure):
libjson0:i386 0.10-1.2yavdr3 cannot be configured because libjson0:amd64 is in a different version (0.9-1ubuntu1)
dpkg: dependency problems prevent configuration of grive:
grive depends on libjson0 (>= 0.10); however:
Version of libjson0 on system is 0.9-1ubuntu1.
grive depends on libjson0-dev (>= 0.10); however:
Version of libjson0-dev on system is 0.9-1ubuntu1.
dpkg: error processing grive (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of grive-tools:
grive-tools depends on libjson0-dev (>= 0.10); however:
grive-tools depends on grive (>= 0.3); however:
Package grive is not configured yet.
dpkg: error processing grive-tools (--configure):
No apport report written because MaxReports is reached already
Errors were encountered while processing:
libjson0
libjson0-dev
libjson0:i386
grive
grive-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
