WIFI Ubuntu připojení, jak ho sem doinstalovat?
WiFi, drátové sítě atd.
ester@infernits.com
#1 Příspěvek od ester@infernits.com »
Dobrý den, vůbec se mi tu neukazuje WIFI (jakože na počítači, jak se k němu připojit)... nevím, co mám dělat. Děkuju za každou radu.
lspci
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
00:01.0 PCI bridge: Intel Corporation Mobile PM965/GM965/GL960 PCI Express Root Port (rev 0c)
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 02)
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 02)
00:1c.3 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 4 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f2)
00:1f.0 ISA bridge: Intel Corporation 82801HM (ICH8M) LPC Interface Controller (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation G86M [Quadro NVS 140M] (rev a1)
03:01.0 CardBus bridge: O2 Micro, Inc. Cardbus bridge (rev 21)
03:01.4 FireWire (IEEE 1394): O2 Micro, Inc. Firewire (IEEE 1394) (rev 02)
09:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5755M Gigabit Ethernet PCI Express (rev 02)
0c:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4311 802.11a/b/g (rev 01)
inxi -F
System:
Host: ester-Latitude-D830 Kernel: 5.4.0-80-generic x86_64 bits: 64
Desktop: MATE 1.24.0 Distro: Linux Mint 20.1 Ulyssa
Machine:
Type: Portable System: Dell product: Latitude D830 v: N/A
Mobo: Dell model: 0UY141 serial: <superuser/root required> BIOS: Dell
v: A17 date: 06/19/2013
Battery:
ID-1: BAT0 charge: 80.4 Wh condition: 80.4/86.6 Wh (93%)
CPU:
Topology: Dual Core model: Intel Core2 Duo T9300 bits: 64 type: MCP
L2 cache: 6144 KiB
Speed: 798 MHz min/max: 800/2501 MHz Core speeds (MHz): 1: 798 2: 798
Graphics:
Device-1: NVIDIA G86M [Quadro NVS 140M] driver: nvidia v: 340.108
Display: x11 server: X.Org 1.20.9 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1280x1024~60Hz
OpenGL: renderer: Quadro NVS 140M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
Audio:
Device-1: Intel 82801H HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.0-80-generic
Network:
Device-1: Broadcom and subsidiaries NetXtreme BCM5755M Gigabit Ethernet
PCI Express
driver: tg3
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: 00:1c:23:b5:69:a3
Device-2: Broadcom and subsidiaries BCM4311 802.11a/b/g driver: N/A
Device-3: Dell Wireless 360 Bluetooth type: USB driver: btusb
Drives:
Local Storage: total: 238.47 GiB used: 159.89 GiB (67.0%)
ID-1: /dev/sda vendor: Apacer model: AS350 256GB size: 238.47 GiB
Partition:
ID-1: / size: 228.18 GiB used: 159.75 GiB (70.0%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 5.64 GiB used: 139.4 MiB (2.4%) fs: swap dev: /dev/sda5
Sensors:
System Temperatures: cpu: 46.0 C mobo: N/A sodimm: 47.0 C gpu: nvidia
temp: 60 C
Fan Speeds (RPM): cpu: 3054
Info:
Processes: 204 Uptime: 2h 55m Memory: 3.84 GiB used: 2.08 GiB (54.2%)
Shell: bash inxi: 3.0.38
Re: WIFI Ubuntu připojení, jak ho sem doinstalovat?
#2 Příspěvek od alojz »
...vypnut secure boot...alebooo vytvorit certifikat,už som to pisal...
...ikonu maš???len nevidno siete???alebočojetam???... :twisted: :twisted: :twisted:
#3 Příspěvek od akojak »
V mate-menu (mint-menu) otvoriť ovládacie centrum a tam sú nastavenia aj pre internet a siete. Tam sa dá nakonfigurovať wifi.
U teba sa to môže líšiť trochu.
Wifi môžeš v terminále vypnúť/zapnúť
nmcli radio wifi off
nmcli radio wifi on
https://www.addictivetips.com/ubuntu-li ... /wifi-sum/
Naposledy upravil(a) akojak dne 02 srp 2021, 12:27, celkem upraveno 1 x.
#4 Příspěvek od Ventero1 »
Musi odinstalovat stary modul bcmwl-kernel-source a nainstalovat nesvobodne drivery - frmware-b43-installer a mozna jeste pripadne linux-firmware - na Ubuforu uz je podrobnejsi navod v odpovedi na stejny dotaz.
#5 Příspěvek od akojak »
Ventero1 píše: 02 srp 2021, 12:17 Musi odinstalovat stary modul bcmwl-kernel-source a nainstalovat nesvobodne drivery - frmware-b43-installer a mozna jeste pripadne linux-firmware - na Ubuforu uz je podrobnejsi navod v odpovedi na stejny dotaz.
Toľko práce nazmar...
Lepšie pochodíš ked si nainstaluješ hocičo iné miesto ubuntu-lm tam funguje wifi .... :lol:
