Upgrade Linux Mintu [vyřešeno]
bambulko
#1 Příspěvek od bambulko »
Upgrade som na fore nenasiel, tak by som sa chcel opytat...
funguje upgrade na novu verziu mintu (zo 16 na 17) tak ako v Linuxe? je mozne to spustit automaticky, alebo bude nutna reinstalacia?
diky za info
Linux Mint 17.3 64-bit, KDE
Allconius
Re: Upgrade linuxu Mint
#2 Příspěvek od Allconius »
upgrade možné je ale moc bych to nedoporučoval, zabere to cca 3 hodiny (na starém HW :-) ). Koukni sám, zde je postup upgrade z LM13 na LM16, který jsem zkoušel:
0. LM13MATE 64bit
1. logout
2. ctrl+alt+F2
3. sudo /etc/init.d/mdm stop
4. sudo pico /etc/apt/sources.list
deb http://packages.linuxmint.com/ petra main upstream import
deb http://archive.ubuntu.com/ubuntu/ saucy main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ saucy-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ saucy-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ saucy partner
5. sudo apt-get update
6. sudo apt-get dist-upgrade
7. při dotazu: z - opravit 13 na 16 a Maya na Petra - exit - n
8. sudo apt-get upgrade -f
9. sudo reboot
10. vase sezeni trvalo mene nez 10 sekund
11. Instal MATE:
deb http://repo.mate-desktop.org/ubuntu saucy main
sudo apt-get --yes --quiet --allow-unauthenticated install mate-archive-keyring
sudo apt-get install mate-core
sudo apt-get install mate-desktop-environment
12. sudo reboot
13. login
14. clear /etc/apt/sources.list
15. sudo pico /etc/apt/sources.list.d/official-package-repositories.list
deb http://packages.linuxmint.com petra main upstream import
deb http://extra.linuxmint.com petra main
deb http://archive.ubuntu.com/ubuntu saucy main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu saucy-updates main restricted universe multiverse
15. sudo apt-get dist-upgrade
16. sudo reboot
17. LM16MATE 64bit
18. DNS fix
sudo dpkg-reconfigure resolvconf
sudo dhclient -v
19. přidat do /usr/share/python-apt/templates/LinuxMint.info
Suite: petra
RepositoryType: deb
BaseURI: http://packages.linuxmint.com/
MatchURI: packages.linuxmint.com
MirrorsFile-amd64: /usr/share/python-apt/templates/LinuxMint.mirrors
MirrorsFile-i386: /usr/share/python-apt/templates/LinuxMint.mirrors
Description: Linux Mint 16 'Petra'
Component: main
CompDescription: Main packages
CompDescriptionLong: Main packages
Component: upstream
CompDescription: Upstream packages
CompDescriptionLong: Upstream packages
Component: import
CompDescription: Imported packages
CompDescriptionLong: Imported packages
Component: backport
CompDescription: Backports
CompDescriptionLong: Backported packages
Component: romeo
CompDescription: Unstable packages
CompDescriptionLong: Unstable packages
bambulko
#3 Příspěvek od bambulko »
no... tak to naozaj nie ;)
v Ubuntu je to jeden klik na UPGRADE a urobi to sam :-/
zistenie: na tomto fore nefunguje hladanie. dal som hladat "upgrade" a nenaslo to ziaden prispevok a pritom tu je minimalne moj a este som nasiel aj tento: http://forum.linux-mint-czech.cz/viewto ... f=15&t=500
Allconius
#4 Příspěvek od Allconius »
vyhledávání funguje :-) píše ti to:
Následující zadaná slova byla při vyhledávání vynechána, protože jsou příliš obecná: upgrade
Musíte zadat minimálně jedno slovo, které chcete vyhledat. Každé slovo musí obsahovat nejméně 3 a maximálně 14 znaků (kromě *).
takže musíš zadate třeba "upgrade linuxu"
KOLEGA
#5 Příspěvek od KOLEGA »
Upgrade distribuce na jedno "klepnutí" (psaní v terminálu) tu je, ale nedoporučuje se ... Psal jsem na to téma dokonce kdysi dávno, ještě v dobách, kdy jsem byl hodně aktivní, článek (Edit: Překládal) http://www.linux-mint-czech.cz/upgrade-linux-mint/
Zažraný linuxový liberál
bambulko
#6 Příspěvek od bambulko »
a fakt :-D
sorry to ma nenapadlo citat :-D
...to bude tym pocasim :)
KOLEGA
#7 Příspěvek od KOLEGA »
V pořádku ... Všichni občas na něco zapomínáme, tak zdravím na Slovensko a označuji za vyřešené ;)
ulo
#8 Příspěvek od ulo »
A stačí si přečíst i naše forum: http://wiki.linux-mint-czech.cz/doku.ph ... ejsi_verzi
