Pred nedavnom som zacal pouzivat Linux Mint 16 Petra.
Rozbehol som satelitnu DVB-S2 kartu s tvheadend (backend) a xbmc (frontend).
Ide mi to celkom pekne, ale dekodovanie videa zjavne vykonava CPU.
Nasiel som nejake navody ohladom instalacie fglrx, ale nepodarilo sa mi to dotiahnut do konca (xbmc potom neprehravalo vobec nic).
Vedel by mi jiekto poradit, ako ako HW akcelerovat video cez GPU ?
GK mam ATI HD RADEON 4550
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710 [Radeon HD 4550] (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited / Sapphire Technology Device e106
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at fdee0000 (64-bit, non-prefetchable) [size=64K]
I/O ports at ce00 [size=256]
[virtual] Expansion ROM at fde00000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: radeon
