nainstaloval jsem na nový počítač Mint a mám problém s programem Chrony.
Neumí to zapsat - vlastně nikam.
Hle:
led 18 22:40:06 NUC25 chronyd[78138]: Loaded 0 symmetric keys
led 18 22:40:06 NUC25 chronyd[78138]: Initial frequency -13.599 ppm
led 18 22:40:06 NUC25 chronyd[78138]: Using right/UTC timezone to obtain leap second data
led 18 22:40:06 NUC25 chronyd[78138]: Could not open /hdd/log/chrony/tracking.log : Permission denied
led 18 22:40:06 NUC25 chronyd[78138]: Loaded seccomp filter (level 1)
led 18 22:40:06 NUC25 systemd[1]: Started chrony.service - chrony, an NTP client/server.
led 18 22:40:07 NUC25 chronyd[78138]: Could not open /hdd/log/chrony/measurements.log : Permission denied
led 18 22:40:12 NUC25 chronyd[78138]: Could not open /hdd/log/chrony/statistics.log : Permission denied
led 18 22:40:13 NUC25 chronyd[78138]: Selected source 130.149.17.8 (ntps1-1.cs.tu-berlin.de)
led 18 22:40:13 NUC25 chronyd[78138]: System clock TAI offset set to 37 secondsKód: Vybrat vše
drwxr-x--- 1 _chrony _chrony 0 led 15 19:25 chrony/Kód: Vybrat vše
drwxrwxrwx 1 _chrony adm 0 led 18 20:14 time/Z configu:
# This directive specify the file into which chronyd will store the rate
# information.
driftfile /hdd/time/chrony.drift
# Uncomment the following line to turn logging on.
log tracking measurements statistics
# Log files location.
logdir /hdd/log/chrony
Pokračování:
nepomáhá ani umístění oněch souborů kamkoliv jinam, na jiný disk, na ramdisk....
led 19 11:24:30 NUC25 systemd[1]: Starting chrony.service - chrony, an NTP client/server...
led 19 11:24:30 NUC25 chronyd[3018]: chronyd version 4.5 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 -DEBUG)
led 19 11:24:30 NUC25 chronyd[3018]: Loaded 0 symmetric keys
led 19 11:24:30 NUC25 chronyd[3018]: Using right/UTC timezone to obtain leap second data
led 19 11:24:30 NUC25 chronyd[3018]: Could not open /ramdisk/tracking.log : Read-only file system
led 19 11:24:30 NUC25 chronyd[3018]: Loaded seccomp filter (level 1)
led 19 11:24:30 NUC25 systemd[1]: Started chrony.service - chrony, an NTP client/server.
led 19 11:24:31 NUC25 chronyd[3018]: Could not open /ramdisk/measurements.log : Read-only file system/ramdisk je přístupný všem vším.
