sudo modprobe -r uvcvideoKód: Vybrat vše
sudo modprobe uvcvideo quirks=32Už mi ale nefunguje když chci aby mi to fungovalo natrvale:
edit the options file (u might have to create one) in:
cd /etc/modprobe.d
gksudo gedit options
At the bottom (or just add it if empty) add the following line:
options uvcvideo quirks=32
